Aug 18th, 2024, 12:11am
which transistor to use (Read 1524 times)
ontheverge
Nov 24th, 2010, 8:20pm
there are a number of choices for MOS transistor in tsmc0.18um process, categorized into rf devices and logic devices.
if I'm to design ADC at 10MS/s conversion rate, which type of transistor should I choose, (what about 50MS/s, what is the criteria?)
For logic devices, it comes with varying Vts, again, what is the criteria for choosing them, i guess it's easy to say that it depends on target speed and power, but can anyone explain in more detail?
thanks,
Steve
Re: which transistor to use
Reply #1 - Nov 26th, 2010, 2:40am
Hi Steve,
Usually the RF transistors are characterized for radio frequency application, where the parasitic cap/res impact the performance. And it has bigger layout area because those RF transistors has guard ring in the layout. So please don't use RF transistors when you design ADC operating at 10MS/s or 50MS/s. I assume you design a nyquist rate ADC.
As of the multiple threshold voltage of MOS, you'd better to use MOS with normal Vth to reduce cost. However, you may use lvt or hvt MOS for high performance or easy design if your boss does not prohibit you from using lvt and hvt MOS.
Yawei
