Jul 19th, 2024, 4:18pm
One variable inside a verilog-A module not saved (Read 3200 times)
Nov 29th, 2010, 7:53pm
Hi Guys,
I tried to save the variables inside a verilog-A module. A part of the verilog-A code is listed below.
`define NUM_ADC_BITS    10
   real unconverted;
   real halfref;
   real vd[0:`NUM_ADC_BITS-1];
   integer i;
Then I chose Outputs --> Save All... --> Select AHDL Variables (saveahdlvars) --> All. I saw unconverted, halfref, and i in the results browser. However, there was no vd. I checked the netlist, it has the following option.
saveOptions options save=allpub subcktprobelvl=3 saveahdlvars=all
The tool versions are IC 6.1.4.500.9, and spectre sub-version  10.1.0.213.isr1.
What's wrong? Any comments are appreciated.
Yawei
Re: One variable inside a verilog-A module not saved
Reply #1 - Dec 1st, 2010, 8:30am
If you make halfref an array, does it disappear also?  Or does it give you a hint on how the signal is named (halfref_bit0 or something)?
Reply #2 - Dec 5th, 2010, 6:30am
Hi Geoffrey,
Yes, it disappears if I make halfref an array, like halfref[0:1]. So I create another integer variable named dat instead of vd[0:`NUM_ADC_BITS-1]. Thanks.
Yawei
Reply #3 - Jan 2nd, 2011, 2:35am
Yawei,
There is a CCR (and a few duplicates) for this - 602394. You might want to get a duplicate filed to increase the likelihood of this being done sooner rather than later.
