Hi Guys,
I tried to save the variables inside a verilog-A module. A part of the verilog-A code is listed below.
Code:`define NUM_ADC_BITS 10
real unconverted;
real halfref;
real vd[0:`NUM_ADC_BITS-1];
integer i;
Then I chose
Outputs -->
Save All... -->
Select AHDL Variables (saveahdlvars) -->
All. I saw unconverted, halfref, and i in the results browser. However, there was no
vd. I checked the netlist, it has the following option.
Code:saveOptions options save=allpub subcktprobelvl=3 saveahdlvars=all
The tool versions are IC 6.1.4.500.9, and spectre sub-version 10.1.0.213.isr1.
What's wrong? Any comments are appreciated.
Yawei
