Jul 19th, 2024, 2:25am
Current dependent voltage source in Spectre (Read 2111 times)
fernando.g.r
Dec 06th, 2010, 2:50am
I'm trying to specify a current dependent voltage source in Spectre, which also depends on a voltage node.
The expresion i'm trying to model is :
V(Emem) = -I(Roff)*V(N1)*(R_OFF-R_ON)
So i tried with no result:
Emem Plus N2 dc=-I(Roff)*V(N1)*(R_OFF-R_ON)
Can you help me? Thanks
Frank Wiedmann
Munich, Germany
Re: Current dependent voltage source in Spectre
Reply #1 - Dec 6th, 2010, 6:40am
You could either try to use the pccvs component (together with a vccs for the control voltage) or write a simple Verilog-A model.
fernando.g.r
Reply #2 - Dec 6th, 2010, 6:44am
Thanks!
I finally include a bsource component, and it seems it works.
Thanks for all.
