Jul 19th, 2024, 8:33am
Spectre parasitic reduction (Read 6512 times)
Rapid
Sweden
Dec 07th, 2010, 1:24am
In the Analog Design Environment/Setup/"Spectre turbo/parasitic reduction", I've enabled Parasitic Reduction and Options, Fmax=5GHz. What does this Fmax parameter actually do? What does Default and RF do? Where can I find more information about it?
Thanks!
Frank Wiedmann
Munich, Germany
Re: Spectre parasitic reduction
Reply #1 - Dec 7th, 2010, 1:54am
You can find this in the section "Parasitic Reduction" right at the beginning of the "Virtuoso Spectre Circuit Simulator User Guide". Default is 1 GHz, RF is 30 GHz. The idea is probably that the circuit behavior remains essentially unchanged by the parasitic reduction up to the specified frequency.
Rapid
Sweden
Reply #2 - Dec 7th, 2010, 2:04am
Oh, thanks! Our version of the manual is from June 2008 so it seems like that information has been added later. Are you having a newer manual?
Frank Wiedmann
Munich, Germany
Reply #3 - Dec 7th, 2010, 4:00am
The information is available in the manual for version 7.2 (May 2010).
