Jul 2nd, 2025, 5:00am
fork join block (Read 2489 times)
Deb
fork join block
Jan 24th, 2011, 6:29am
Dear All,
Please help me in the following issue.
I am giving here a code snippet. Please look into this.
fork : globalOperator
           real timeOfStart;
           integer setMatchHigh;
           real timeOfMatch;
           timeOfStart = $abstime;
                $display("Fork Entered for %d time and timeOfStart for this fork is %f: \n", countStart, timeOfStart);
/*             forever begin
                while (($abstime - timeOfStart) < delay)
         begin
                     if(!setExpr)
        begin
         $display("Expr became low before delay time exceeded and hence Thread disabled. \n");
           disable globalOperator;
        else
        begin
           match = 1'b0;
                 forever begin
                 @(cross(($abstime - (timeOfStart + delay)), +1, TimeTolerance))
    begin
                 setMatchHigh = 1;
                      $display("setMatchHigh is made high. \n");
     timeOfMatch = $abstime;
         if(setExpr && setMatchHigh)
   begin
                 match = 1'b1;
 countMatch = countMatch + 1;
                @(cross(($abstime - (timeOfMatch + KeepMatchHighTime)), +1, TimeTolerance))
       begin
   if(match)
           begin
      match = 1'b0;
      $display("%d Match was detected and match signal is made low: \n", countMatch);
       join
Within the fork block, after each thread is created, I want to check setExpr for delay value after timeOfStart. For that I have used the while loop but its basically stalling the simulation. How can I do that within the fork block? Please suggest.  Also please suggest how can I use a cross statement within the fork block.
Thanks in advance for your kind support.
Thanking you,
Yours sincerely,
Debjit
Debjit Pal
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: fork join block
Reply #1 - Feb 2nd, 2011, 6:17am
There is no delay in your while loop, so it will continue to evaluate the code, never progressing through time. If you add a delay anywhere in the loop the while loop will probably work. However, this is a kind of "polling"technique which is quite costly in terms of performance and only as accurate as the delay value you specify. You might want to rework this into an event-driven test case, for instance an event that triggers on any change in setExpr.
Cheers,
Marq
Deb
Re: fork join block
Reply #2 - Feb 2nd, 2011, 7:42am
Hi Marq,
Yep !! You are very correct.. I am implemented it already in other fashion with a concept of loop unrolling.. But anyways.. Thanks for your kind support...
Yours sincerely,
Debjit .
Debjit Pal.
