As Geoffrey asked, are you using a recent version of spectre (if so, what is it?). Ken's point is valid too (although I think that's handled OK nowadays, but I didn't check).
I wouldn't recommend using spp. This is obsolete and has not be maintained for maybe 6 years or so. The supported flow is to read the model directly in spectre. Ideally if it's in SPICE syntax, make sure the file name it is included in does not end in ".scs" (which means spectre syntax by default), and then it should behave.
Maybe you can show the error message you're getting?
