Aug 16th, 2024, 7:54pm
hspice to spectre model conversion (Read 6825 times)
jazzdup
Jan 25th, 2011, 10:59am
Hello, I have a level=49 hspice model and need to convert to a spectre-readable model. Any advice? Thanks.
Re: hspice to spectre model conversion
Reply #1 - Jan 26th, 2011, 5:42am
Did you try just running it straight?  The Cadence folks on this board often mention Spectre's ability to read (H)Spice syntax; for a single model, I would expect it to work.
bernd
Munich/Germany
Reply #2 - Jan 26th, 2011, 6:21am
You may try the Cadence command line tool 'spp'.
There is also an old App. Note on SourceLink (http://support.cadence.com)
'BSIM3V3.X MOSFET Model Compatibility:
HSPICE Level 49 - Spectre BSIM3V3.X'
http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q...
which may help.
* bernd
Just another lonesome cad guy
jazzdup
Reply #3 - Jan 26th, 2011, 8:16am
Thanks to all who replied.
Running it straight without modification throws an error at the level=49 specification.
We did try the spp command but that threw an error as well after the second line. The error msg was not helpful, something about an 'unexpected new line character after VERSION ='. There wasn't a new line character on that line.
I'll the cadence app note and give it another shot. Thanks again.
Reply #4 - Jan 26th, 2011, 9:58am
Are you using a recent version of Spectre?
bernd
Munich/Germany
Reply #5 - Jan 27th, 2011, 5:08am
It might be useful to check the model syntax definition as
well. An unexpected new line error might result form a missing
'+' as new line indicator or a missing '\' as a end of line
statement.
* bernd
Reply #6 - Jan 27th, 2011, 8:27am
If the file came from a different operating system it might be using a different convention for newllines. You might try opening it in vim and typing
:set fileformat
If is says 'fileformat=unix' then this is not the problem. If it doesn't, you should type
:set fileformat=unix
and the save the file with
:wq
Reply #7 - Jan 30th, 2011, 1:23pm
As Geoffrey asked, are you using a recent version of spectre (if so, what is it?). Ken's point is valid too (although I think that's handled OK nowadays, but I didn't check).
I wouldn't recommend using spp. This is obsolete and has not be maintained for maybe 6 years or so. The supported flow is to read the model directly in spectre. Ideally if it's in SPICE syntax, make sure the file name it is included in does not end in ".scs" (which means spectre syntax by default), and then it should behave.
Maybe you can show the error message you're getting?
