Nov 21st, 2026, 6:53pm
HSPICE error: reference not found (Read 5886 times)
jszair
Jan 31st, 2011, 1:17pm
Hi all, I run into an error in hspice saying that my reference is not found. But i included the model file and the simulation log also shows the model file is included.
Also, the model didn't set lmax/min or wmax/min...
Please help. THanks!
error message:
**error** reference        0:nmos not found, or instance width or length does not fit into the wmax/wmin or lmax/lmin range.
     it was referenced in element         0:mn
     the channel width=   1.000E-04 and length=   3.500E-07
   the line number was      11
here's the spice deck
.inc 'tsmc018.sp'
.param ds=0.9
.param gs=1
vdsn vdn 0 dc 'ds'
vgsn vgn 0 dc 'gs'
mn vdn vgn 0 0 nmos L=.35u W=100u
.op
.options nomod dccap post brief
.dc gs 0.2V 1.2V 10mV
and the model file (too long to be included) is attached, (change the extension to sp)
« Last Edit: Feb 01st, 2011, 9:58am by jszair »
haykp
Re: HSPICE error: reference not found
Reply #1 - Jan 31st, 2011, 10:56pm
Most probably you have specify the channel length or width that doesn't fit into Lmin< L < Lmax  or Wmin <W<Wmax. So check whether your given W or L fit into that range.
jszair
Reply #2 - Feb 1st, 2011, 8:05am
There is no lmax/wmax or lmin/wmin in the model file.
.35 micron length and 100 micron width are very normal W/L number...
Reply #3 - Feb 1st, 2011, 9:57am
Is the .inc on the first line?  Remember, Spice treats the first line as a comment.  (I once had a .temp command as the first line, and the simulator printed that comment several times through the log file, which I took to mean it had used that temp, but really it was just printing the comment.)
Also, TSMC is probably not going to like you posting proprietary information on a public forum ...
