Jul 19th, 2024, 10:30am
Spectre Turbo - Parasitic Reduction - Fmax (Read 5280 times)
Berti
Feb 04th, 2011, 7:07am
When I enter a value smaller than 1 (e.g. 0.1) into the fmax option field of the spectre turbo parasitic reduction (using icfb 5.10.41), it get an error warning: "Invalid value specified for Fmax. Switching to default parasitic reduction mode."
Can the value of fmax be smaller than 1GHz? Is my formating wrong or is that just another bug? As usual, I haven't found anything in the documentation.
Thanks for help, Cheers
Re: Spectre Turbo - Parasitic Reduction - Fmax
Reply #1 - Feb 4th, 2011, 10:57am
Are you sure that field has units of GHz, not Hz?
Reply #2 - Feb 5th, 2011, 8:47am
Berti,
 Originally the minimum value of fmax was limited to 1GHz. In more
recent versions of MMSIM/IC, fractional values are supported.
Berti
Reply #3 - Feb 6th, 2011, 11:45pm
Thanks a lot Sheldon!
By the way, what is the actual meaning of fmax? What I mean is: Is the simulation accuracy guarantied for ≤fmax, or is fmax the maximum frequencies where parasitcs are taken into account (what would mean that my fmax in the simulation should be smaller)?
boe
Reply #4 - Mar 7th, 2011, 9:39am
Berti,
"An important input to the parasitic reduction technology is the relevant frequency of interest. The parasitic reduction algorithm tries to preserve circuit accuracy up to this frequency."
 -- CadenceŽ VirtuosoŽ SpectreŽ Circuit Simulator and Accelerated Parallel Simulator User Guide, Product Version 10.1 (Sept 2010)
B O E
