Oct 3rd, 2026, 9:24pm
Pages: 1 2
Simulator gives error if parameters are changed (Read 18279 times)
JussiS
Scandinavia
Feb 09th, 2011, 4:00am
Has anyone else encountered a problem where the simulator (Cadence AMS) gives an error, if you change any of the parameters in a component from the schematic properties-view?
The error it gives is:
ncelab: *E,CUBSPA (./ihnl/Buck_vcm/Buck_voltage/schematic/verilog.vams,26||44): Assigment of string to real or integer type parameter.
The code is:
/Verilog-AMS HDL for "Buck_vcm", "Compensator" "verilogams"
`include "constants.vams"
`include "disciplines.vams"
module Compensator ( Vref, Vin, Vout);
input Vref, Vin;
output Vout;
parameter real Pole_a = 10;
parameter real Pole_b = 100e4;
parameter real Pole_c = 100e5;
parameter real Zero_a = 1000;
parameter real Zero_b = 20e3;
parameter real Gain_dB=20;
real PI=3.14159265;
real Poles[0:5];
real Zeros[0:3];
real Gain;
electrical Vin, Vref, Vout;
 analog begin
  Gain = pow(10,(Gain_dB/20));
  Poles[0] = -2*PI*Pole_a;
  Poles[1] = 0;
  Poles[2] = -2*PI*Pole_b;
  Poles[3] = 0;
  Poles[4] = -2*PI*Pole_c;
  Poles[5] = 0;
 Zeros[0] = -2*PI*Zero_a;
  Zeros[1] = 0;
  Zeros[2] = -2*PI*Zero_b;
  Zeros[3] = 0;
  V(Vout) <+ Gain*laplace_zp(V(Vref,Vin),Zeros,Poles);
If I don't touch the properties, the simulation is completed normally.
Re: Simulator gives error if parameters are changed
Reply #1 - Feb 9th, 2011, 9:12am
Seems like a problem with the netlisting code -- I bet, when you specify a parameter, you get
 Pole_a = "10"
instead of
 Pole_a = 10
on the instance line.
JussiS
Scandinavia
Reply #2 - Feb 9th, 2011, 9:38pm
So it would be bug in software itself?
How should one go about fixing the issue?
Reply #3 - Feb 11th, 2011, 4:06am
You might need to look into the CDF parameters that you defined for the symbol; I'll bet you have valueType "string" instead of valueType "int"
Did you create the symbol?  If not, you may need help from the person who did.
JussiS
Scandinavia
Reply #4 - Feb 11th, 2011, 5:39am
Geoffrey_Coram wrote on Feb 11th, 2011, 4:06am:
Yes, I created the symbol myself and was not aware that I have to define the CDF parameters outside of the verilog-ams code.
In the code the are defined: "parameter real nameofparameter".
Or then I'm 'missing' something here. Could you please elaborate on the subject of the CDF parameters?
Thanks for the info so far.
Reply #5 - Feb 12th, 2011, 3:13pm
Please enter in the CIW:
cdfDump("Buck_vcm" "Compensator.cdf" ?cellName "Compensator")
and then post the contents of the file Compensator.cdf here.
JussiS
Scandinavia
Reply #6 - Feb 13th, 2011, 11:04pm
Here you go:
LIBRARY = "Buck_vcm"
CELL    = "Compensator"
let( ( libId cellId cdfId )
   unless( cellId = ddGetObj( LIBRARY CELL )
       error( "Could not get cell %s." CELL )
   when( cdfId = cdfGetBaseCellCDF( cellId )
       cdfDeleteCDF( cdfId )
   cdfId  = cdfCreateBaseCellCDF( cellId )
   ;;; Parameters
   cdfCreateParam( cdfId
       ?name           "Pole3"
       ?prompt         "Pole3"
       ?defValue       "1e+07"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Pole3)"
       ?parseAsNumber  "yes"
       ?parseAsCEL     "yes"
       ?name           "Gain"
       ?prompt         "Gain"
       ?defValue       "0"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Gain)"
       ?name           "Pole1"
       ?prompt         "Pole1"
       ?defValue       "10"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Pole1)"
       ?name           "Zero1"
       ?prompt         "Zero1"
       ?defValue       "100"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Zero1)"
       ?name           "Pole2"
       ?prompt         "Pole2"
       ?defValue       "100"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Pole2)"
       ?name           "Zero2"
       ?prompt         "Zero2"
       ?defValue       "1"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Zero2)"
       ?name           "Pole"
       ?prompt         "Pole"
       ?defValue       "10"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Pole)"
       ?parseAsCEL     "yes"
       ?name           "Pole_b"
       ?prompt         "Pole_b"
       ?defValue       "7.9477e+06"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Pole_b)"
       ?name           "Pole_c"
       ?prompt         "Pole_c"
       ?defValue       "2e+12"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Pole_c)"
       ?name           "Zero_a"
       ?prompt         "Zero_a"
       ?defValue       "0.1"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Zero_a)"
       ?name           "Zero_b"
       ?prompt         "Zero_b"
       ?defValue       "794770"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Zero_b)"
       ?name           "Pole_a"
       ?prompt         "Pole_a"
       ?defValue       "1e-05"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Pole_a)"
       ?name           "Gain_dB"
       ?prompt         "Gain_dB"
       ?defValue       "0"
       ?type           "string"
       ?display        "artParameterInToolDisplay('Gain_dB)"
   ;;; Properties
   cdfId->formInitProc            = ""
   cdfId->doneProc                = ""
   cdfId->buttonFieldWidth        = 340
   cdfId->fieldHeight             = 35
   cdfId->fieldWidth              = 350
   cdfId->promptWidth             = 175
   cdfId->viewInfo                = '(nil verilogams (nil moduleName "Compensator" namePrefix "ahdl"
termOrder (Vref Vin Vout) parameterList (Pole_a Pole_b Pole_c Zero_a Zero_b
   Gain_dB
   cdfSaveCDF( cdfId )
JussiS
Scandinavia
Reply #7 - Feb 13th, 2011, 11:05pm
And I'm guessing the problem is:
      ?name           "Pole3"
      ?prompt         "Pole3"
      ?defValue       "1e+07"
      ?type           "string"    <-Right there??
-Jussi
Reply #8 - Feb 14th, 2011, 5:59am
JussiS wrote on Feb 11th, 2011, 5:39am:
How did you create the symbol?  Did you use "create cellview from cellview" or something?  (I've never made a symbol for a Verilog-AMS module myself.)  I would think that, if the CDF parameters for the symbol were automatically generated from the .vams file, then they should have the right data type.
Reply #9 - Feb 14th, 2011, 6:21am
JussiS wrote on Feb 13th, 2011, 11:05pm:
      ?name           "Pole3"
      ?prompt         "Pole3"
      ?defValue       "1e+07"
-Jussi
Yep.  Also the defValue is "1e+07" (a string) rather than 1+e07 (a floating-point number).
Perhaps Andrew can tell you how to load the cdf back in, after you change all those "string" to "real"
JussiS
Scandinavia
Reply #10 - Feb 15th, 2011, 4:19am
Geoffrey_Coram wrote on Feb 14th, 2011, 5:59am:
I first created the Verilog-AMS cellview and after saving and closing the file, Cadence says, that no symbol exists, would you like to create it?
Click yes and the symbol view appears in the listing of the components views.
JussiS
Scandinavia
Reply #11 - Feb 20th, 2011, 10:54pm
Geoffrey_Coram wrote on Feb 14th, 2011, 6:21am:
      ?name           "Pole3"
      ?prompt         "Pole3"
      ?defValue       "1e+07"
-Jussi
What is Andrews nick on this board? (Probably just "Andrew", but gotta ask anyways).
Reply #12 - Feb 22nd, 2011, 5:26am
I meant Andrew Beckett, who responded earlier in this thread.
JussiS
Scandinavia
Reply #13 - Apr 4th, 2011, 10:01pm
Tried contacting Andrew with a PM, but no response so far (it's been a month).
Anybody else have any idea as to how to fix this?
boe
Reply #14 - Apr 5th, 2011, 7:22am
JussiS,
the output of cdfDump looks like a SKILL script to me, so you should try to just run it. But you could also use the CDF tool to change this directly with the GUI.
BTW, you could also leave the parameter type as string and change the parseAsNumber...
       ?name           "Pole3"
       ?prompt         "Pole3"
       ?defValue       "1e+07"
       ?type           "string"
       ?parseAsNumber  "yes"  ;; needed for all numeric values w type=string
       ?parseAsCEL     "yes"     ;; may also be needed
Does this help?
B O E
Pages: 1 2
