Aug 15th, 2024, 3:02am
AMS and monte-carlo (Read 2655 times)
sutapanaki
AMS and monte-carlo
Feb 10th, 2011, 4:54pm
I face an unexpected problem here and hope you can help me resovle it. I’m simulating a circuit in which I have instantiated a veriloga/ms block. That block apart from many other things also writes into a file. I must run monte-carlo simulations on that circuit and I rely on the data written to the file to extract statistics and do more processing. I was hoping that I’ll get a separate file for every monte-carlo run (my MC simulation has 100 runs) but it seems that spectre over-writes the files during every MC run. Is there a way that I can get separate files for each and every MC run or is there a way that the data from every MC run gets appended into a single file?
I’m running my simulation in distributed mode on the network so I guess at any moment there are at least 4 MC runs running.
Frank Wiedmann
Munich, Germany
Re: AMS and monte-carlo
Reply #1 - Feb 11th, 2011, 12:28am
Put a %A into your filename (this inserts the analysis name) and select "Save Data Between Runs to Allow Family Plots".
sutapanaki
Reply #2 - Feb 12th, 2011, 3:30am
Thanks. Works!
