Sep 27th, 2026, 4:31pm
2 analog events causing "Process stopped by UNIX signal 6" (Read 6196 times)
fabian
Europe
Feb 14th, 2011, 8:42am
Dear All,
I am hoping my problem is an interest for the forum. I have just been registered to our community and I wonder if I could have a tip on the following issue.
My code is as follow:
electrical in;
parameter real V_th=0.0;
parameter real ttol=10p;
parameter integer dir=1;
parameter integer flag_start=0;
real t1, v_meas;
analog begin
   @(cross(V(in)-V_th,dir,ttol)) begin
     t1=$abstime;
     flag_start <= 1;
//      $strobe("time: %g", t1);
   @(timer(t1, 1u)) begin
     if (flag_start==1) begin
       v_meas = V(in);
       $strobe("value: %e", v_meas);
This veriloga breaks the simulation with the message I have put in the subject. What I would like to implement is an event based on the outcome of an other. If I remove the condition "if", the two events are running without any issue but the second event is not waiting t1 value to be affected before to start.
Thanks for your feedback and remarks,
Fabian
Re: 2 analog events causing "Process stopped by UNIX signal 6"
Reply #1 - Feb 14th, 2011, 10:21am
There's something odd about what you typed:
  flag_start <= 1;
What's this line doing?  You can't change the value of a parameter from within the module.
fabian
Europe
Reply #2 - Feb 14th, 2011, 3:12pm
Hi Goeffrey,
This line is to change the flag value once the first even is true. The second event could then to effectively something as the if statement become true with the flag equal to 1.
So should I change my line to be
or should I initialize under initial bengin end
Fabian
Reply #3 - Feb 15th, 2011, 5:11am
I would do
 integer flag_start;
and then in the analog block,
@(initial_step)
 flag_start = 0;
I'm not sure that initialization as part of the declaration statement is supported by all simulators.  Variables are initialized to zero automatically, per the LRM, but it's more clear to the reader if you show the initialization.
fabian
Europe
Reply #4 - Feb 17th, 2011, 4:01am
Hi Geoffrey,
Thanks is work.
My code looks like now
electrical in;
real t1, v_meas;
analog begin
    flag_start = 1;
  @(timer(0, 1u)) begin
      v_meas = V(in);
What I do not understand it is why I have to start an event (@timer ) from 0us and do nothing until the flag is true instead of having this event starting from a time t1 as shown in my first code.
Thanks Fabian
Reply #5 - Feb 17th, 2011, 6:57am
Did you try setting t1 to 1e6 (or something large) @(initial_step)?
Then the cross will set t1 to a value that will be hit.
fabian
Europe
Reply #6 - Feb 17th, 2011, 8:28am
Thanks it works.
I understand that I need to put t1=$abstime+10n instead of t1=$abstime; otherwise the event @timer does not start.
Thanks it closed the issue, I believe.
