Jul 16th, 2024, 11:21pm
45nm in LTspice (Read 7790 times)
koma
45nm in LTspice
Feb 18th, 2011, 12:19pm
Dear all
I am trying to build an analog circuit using 45nm technology using LTspice simulator.the problem is when I include the 45nm tech file(Techfile_45nm.scs from the PTM(attached with this post)) I am getting this error from LTspice"simulator:missing node(s)".when I try another technology files like IBM90nm.txt it works fine.
can any one advise me about this problem.
regards,
Re: 45nm in LTspice
Reply #1 - Feb 22nd, 2011, 5:34am
Does LTspice read Spectre format files?
I would:
a) rename the file to Techfile_45nm.sp
b) delete "simulator lang=spice"
c) if that's not enough, try removing all the blank lines and comment lines from within each model card (leave a blank line before the pmos card, but each line from the .model to the last line of the model card should start with "+")
