Does LTspice read Spectre format files?
I would: a) rename the file to Techfile_45nm.sp b) delete "simulator lang=spice" c) if that's not enough, try removing all the blank lines and comment lines from within each model card (leave a blank line before the pmos card, but each line from the .model to the last line of the model card should start with "+")
