latha
Hi All,
We are looking for:Lead Developer, Physical Design
This position is expected to be highly experienced (8-10 years). The experience can be in one or more of the following three areas (in order of preference): (i) EDA methodology/flow development (ii) EDA vendor AE (iii) Digital design engineer. He/she should have expert working knowledge of the design flow and relevant EDA tools (Cadence expertise preferred) in the domain. Must have working knowledge of complete netlist to GDSII physical implementation flow. Should have knowledge of technology setup and other inputs that are typically needed to drive physical design tools. Should be able to understand silicon technology documents and develop tech files to specify the required DRC rules. Will be expected to ensure reasonable correlation between physical design and the various signoff areas Should understand static timing analysis including concepts such as OCV. Cadence EDI experience preferred Tools: Preferable to have work experience with Cadence tools, but experience with other tools too would be considered. Scripting and software languages: Perl / Tcl / C++
pls send ur cv's to hr@callidasoft.com
Thanks latha
