Jan 7th, 2026, 1:06pm
Cadence ADE vs Matlab (Read 6387 times)
vp1953
Feb 24th, 2011, 3:44pm
I am wondering if it is possible to do loop filter and open loop gain phase plots for PLL's using Cadence ADE. Normally I use Matlab for this and several people in this forum have alluded to the fact that it is possible to do the analysis in Cadence ADE itself.
I am specifically interesting in knowing how to use laplace domain models for the oscillator, phase detector etc in Cadence ADE.
Thank you in advance.
Re: Cadence ADE vs Matlab
Reply #1 - Feb 24th, 2011, 4:33pm
vp1953,
   You could try laplace functions in Verilog-A or look at
spectre -h svcvs.
vp1953
Reply #2 - Feb 25th, 2011, 2:48pm
Hi Sheldon,
Many thanks!
For laplace functions in verilog-a, what analysis would be recommended for gain/phase plots. I am just reading up on this and there seems to be an opinion that small signal ac analysis is not supported for laplace functions in veriloga.
Reply #3 - Feb 25th, 2011, 9:26pm
vp1953,
    I was a little bit lazy and used an svcvs source and ran a quick
test, as you can see the laplace function does work with ac analysis.
I have not tried the Verilog-A laplace but it should work also. I saw
the comment also and it was not directly related to the laplace
function. The comment was related to using the z-transform
capability of Verilog-A.
vp1953
Reply #4 - Feb 26th, 2011, 8:58am
Hi Sheldon,
Thank you very much again!!
I tried small signal ac analysis with the low pass filter available in the ahdl library and it does not seem to work with ac analysis; the filter however is a time domain model and does not have any laplace functions in it.
I have one other question -
I am currently reading up on the phase domain model of the PLL available at
http://www.designers-guide.org/Analysis/PLLnoise.pdf
Can this model be used to run small signal ac analysis to get gain/phase plots?
