Marq Kole
![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif)
![](https://designers-guide.org/forum/avatars/devil.gif)
Hmmm. That's weird...
Eindhoven, The Netherlands
Hi Geoffrey,
There is some sort of interaction between the natures defined in the disciplines.vams and the quantities defined as part of Spectre. I do not know the detailss, but I do sometimes get warnings about temperature quantity redefined from K to degree C or vice versa. So I do agree that they ought to work but apparently they don't.
Hi Richardsim,
Is this the only Verilog-A module you have in your design or do you have more than this? If that is the case you will probably have to do the `defines in each module that is compiled - even the Verilog-A modules that are part of your PDK if you use that.
Cheers, Marq
