Sep 17th, 2026, 2:54pm
Solving ODE in Verilog-AMS (Read 4773 times)
Sumit Adhikari
Mar 28th, 2011, 2:38am
Does anybody has any idea, if it is possible to solve an ODE in Verilog-AMS ? All my tries failed.
Sumit
boe
Re: Solving ODE in Verilog-AMS
Reply #1 - Mar 28th, 2011, 7:18am
Sumit,
What do you want to achieve? It should be obvious how to solve an ODE if you use a time derivative, so I suppose that's not what you want.
B O E
Sumit Adhikari
Reply #2 - Mar 28th, 2011, 7:52am
You are absolutely correct, I also thought that way. I am in need to solving current and voltage equations as the way I wish  and add them with some other currents/voltages. I want to study transport equations modified quantum mechanical effects in DSM technology, for this Verilog-AMS is good, as I have good controllability. For a warm up I took SHM equation (ddt(ddt(V(p,n))) <+ -k * V(p,n), which should give me sinusoidal out put like a0*sin(wt). Following is the code :
`include "discipline.vams"
`include "constants.vams"
module oscillations_ode (p, n);
   inout               p ;
   inout               n ;
   electrical          p ;
   electrical          n ;
   electrical          d_1 ;
   electrical          d_2 ;
   parameter real k   = 10000.0      ;
   real reff;
   analog
   begin//{
       //@(initial_step)
       @(initial_step("dc", "ac", "tran", "xf"))
       begin//{
         V(p,n)   <+ 1.0 ;
         V(d_1,n) <+ 0.0 ;
         V(d_2,n) <+ 0.0 ;
       end//}
       V(d_1,n) <+ ddt(V(p,n)) ;
       V(d_2,n) <+ ddt(V(d_1,n)) ;
       V(d_2,n) <+ -k*V(p,n) ;
   end //}
output of this block (p) is driving a small parallel load of a resistor and a capacitor.
The solver is running, but I am always getting 0 output.
Do not understand why  >:(
Sumit
boe
Reply #3 - Mar 29th, 2011, 6:39am
Sumit,
your code is wrong.
is equivalent to Code:
V(d_2,n) <+ ddt(V(d_1,n)) - k*V(p,n) ;
which is not what you want. Correct would e.g. be Code:
V(p,n) <+ -1/k*V(d_2,n) ;
This works with my simulator.
B O E
PS: You misused the contribution statement. It is not an assignment.
Sumit Adhikari
Reply #4 - Apr 1st, 2011, 10:56am
Thanks for pointing out my mistake.
Sumit
Sumit Adhikari
Reply #5 - Apr 1st, 2011, 10:58am
Sumit
