Jul 17th, 2024, 12:28pm
Oscillator different simulation Results SMASH - ADE (Read 3653 times)
Zorro
Mar 29th, 2011, 3:18am
Hello Everybody,
I am trying to model a simple oscillator in verilogA.
The main restrictions are:
1. It oscillates only if the Supply Voltage is bigger than a threshold (1V) and if the stby Signal is less than (Supply Voltage)/2.
2. If the required conditions are met (state signal is high), the cell oscillates after a delay of startup_delay.
So far so good.
The simulation of the circuit in SMASH shows the expected result.
However, if I use the same verilogA Model in ADE it doesn't work correctly.
Can please someone have a look at it? I was thinking maybe it is because of the simulation settings but in ADE but I really don't think so.
Please check the internal signal slope.
Attached you will find:
a. The verilogA Code (it's verilogAMS but limited to verilogA).
b. The Testbench (spice Netlist)
c. Some screenshots from SMASH showing the expected result.
The problem is when simulating the oscillator in ADE I don't get some pulses, only a peak.
Thanks for your support
Zorro
Re: Oscillator different simulation Results SMASH - ADE
Reply #1 - Mar 29th, 2011, 3:19am
this is the verilogA code:
`include "disciplines.vams"
`include "constants.vams"
module oscillator (stby, clk_1mhz, vdd_1v8, vss);
     inout            stby, clk_1mhz, vdd_1v8, vss;
     electrical      stby, clk_1mhz, vdd_1v8, vss;
     parameter real fc   = 1e6 from (0:inf); // Frequency of the Oscillator (Hz)
     parameter real kv   = 0.0;                  // Gain (Hz/V)
   parameter real duty = 0.5 from (0:1);   // Duty Cycle.   Example: duty = 0.5
   parameter real threshold=1.0;              // vdd_1v8 must be higher than threshold for the oscillator to operate
   parameter real td=0.1n;                 // Default Delay Time for Transitions
   parameter real tr=0.1n;                 // Default Rise  Time for Transitions
   parameter real tf=0.1n;                 // Default Fall  Time for Transitions
   parameter startup_delay = 0.2u;         // Startup Delay Time for Signal clk_1mhz
   parameter real current_on=3u;           // Current Consumption when Cell is ON
   parameter real current_off=0.2u;        // Current Consumption when Cell is OFF (or not correctly biased)
   real vdd_1v8_ok, stby_ok, state, t1, icc, slope, vout_temp;
   // only for test purposes
   electrical slope_e, state_e;
   analog begin
       @(initial_step) begin
           slope = 1.0;
           state = 0.0;
           t1 = 0.0;
       // Monitoring the vdd_1v8 Signal
           @(cross( V(vdd_1v8) - threshold, 0) or initial_step)
           if (V(vdd_1v8) > threshold) vdd_1v8_ok = 1.0;   // Supply Voltage is higher than the mimimum threshold
       else                        vdd_1v8_ok = 0.0;   // Supply Voltage is lower  than the mimimum threshold
           // Monitoring the stby Signal
       @(cross( V(stby) - (V(vdd_1v8)/2), 0) or initial_step)
           if (V(stby) < (V(vdd_1v8)/2))   stby_ok = 1.0 * vdd_1v8_ok;        // Oscillator is enabled
       else                            stby_ok = 0.0 * vdd_1v8_ok;        // Oscillator is disabled
       // Monitoring the state (ON/OFF) of the oscillator
       @(cross( vdd_1v8_ok - 0.5, 0) or cross( stby_ok - 0.5, 0) or initial_step)
       if (vdd_1v8_ok*stby_ok>0.5) begin
           state = 1.0;
       end else begin
           state = 0.0;
       // Controlling the slope Signal
       @(cross( state - 0.5, +1)) begin
           t1 = $abstime;
           slope = -1.0;
       if (state>0.5) begin
           @(timer(t1+startup_delay, duty/fc)) slope = -1.0 * slope;
       end else begin
           slope = slope;
       @(cross( state - 0.5, 0))
       if (state>0.5)  icc = current_on;
       else            icc = current_off;
       I(vdd_1v8, vss) <+ icc;
       vout_temp = 0.5 * (slope + 1.0) * state;
       // Output Signals
       V(clk_1mhz)     <+ vout_temp * V(vdd_1v8);
       V(slope_e)      <+ slope;
       V(state_e)      <+ state;
Zorro
Reply #2 - Mar 29th, 2011, 3:20am
and this is the file for the testbench:
.lib oscillators_wo_idt.vams
Vsupply vdd_1v8 0 PWL 0 0 200n 1.8 875n 1.8 900n 1.2 925n 1.8 1.8u 1.8  2.9u 1.8 3u 0 3.5u 0 3.6u 1.8 //6.6u 1.8 6.61u 0 7.6u 0 7.61u 1.8
Vstby stby 0 PWL 0 1.8 400n 1.8 500n 0 1.75u 0 1.775u 0.8 1.8u 0 5u 0 5.1u 1.8  5.6u 1.8  5.7u 0
xosc1  stby  clk_1mhz vdd_1v8 0 oscillator
Thank you for your help!
 :)- Zorro
Zorro
Reply #3 - Mar 29th, 2011, 4:11am
this is the simulation result from ADE.
the slope signal reacts (goes high) when conditions are met and after the specified delay but then it goes low inmediately. It should remain high for half the period.
if you compare the results in SMASH are as expected.
How can this be?
thank you!
Reply #4 - Apr 6th, 2011, 9:44am
This looks suspicious to me:
	 end else begin
	     slope = slope;
I don't think it's a good idea to put a timer inside an if statement.  I'd reverse it:
	 @(timer(t1+startup_delay, duty/fc)) begin
