Zorro
this is the verilogA code:
`include "disciplines.vams" `include "constants.vams"
module oscillator (stby, clk_1mhz, vdd_1v8, vss);
inout stby, clk_1mhz, vdd_1v8, vss; electrical stby, clk_1mhz, vdd_1v8, vss;
parameter real fc = 1e6 from (0:inf); // Frequency of the Oscillator (Hz) parameter real kv = 0.0; // Gain (Hz/V) parameter real duty = 0.5 from (0:1); // Duty Cycle. Example: duty = 0.5 parameter real threshold=1.0; // vdd_1v8 must be higher than threshold for the oscillator to operate parameter real td=0.1n; // Default Delay Time for Transitions parameter real tr=0.1n; // Default Rise Time for Transitions parameter real tf=0.1n; // Default Fall Time for Transitions parameter startup_delay = 0.2u; // Startup Delay Time for Signal clk_1mhz
parameter real current_on=3u; // Current Consumption when Cell is ON parameter real current_off=0.2u; // Current Consumption when Cell is OFF (or not correctly biased)
real vdd_1v8_ok, stby_ok, state, t1, icc, slope, vout_temp;
// only for test purposes electrical slope_e, state_e;
analog begin @(initial_step) begin slope = 1.0; state = 0.0; t1 = 0.0; end // Monitoring the vdd_1v8 Signal @(cross( V(vdd_1v8) - threshold, 0) or initial_step) ; if (V(vdd_1v8) > threshold) vdd_1v8_ok = 1.0; // Supply Voltage is higher than the mimimum threshold else vdd_1v8_ok = 0.0; // Supply Voltage is lower than the mimimum threshold // Monitoring the stby Signal @(cross( V(stby) - (V(vdd_1v8)/2), 0) or initial_step) ; if (V(stby) < (V(vdd_1v8)/2)) stby_ok = 1.0 * vdd_1v8_ok; // Oscillator is enabled else stby_ok = 0.0 * vdd_1v8_ok; // Oscillator is disabled
// Monitoring the state (ON/OFF) of the oscillator @(cross( vdd_1v8_ok - 0.5, 0) or cross( stby_ok - 0.5, 0) or initial_step) ; if (vdd_1v8_ok*stby_ok>0.5) begin state = 1.0; end else begin state = 0.0; end
// Controlling the slope Signal @(cross( state - 0.5, +1)) begin t1 = $abstime; slope = -1.0; end if (state>0.5) begin @(timer(t1+startup_delay, duty/fc)) slope = -1.0 * slope; end else begin slope = slope; end
// Current Consumption @(cross( state - 0.5, 0)) ; if (state>0.5) icc = current_on; else icc = current_off; I(vdd_1v8, vss) <+ icc;
vout_temp = 0.5 * (slope + 1.0) * state;
// Output Signals V(clk_1mhz) <+ vout_temp * V(vdd_1v8); // only for test purposes V(slope_e) <+ slope; V(state_e) <+ state;
