Aug 16th, 2024, 6:30pm
question on the "ddt" usage (Read 2816 times)
Patrick520
Hong Kong
Apr 03rd, 2011, 8:12am
Hi!
I am new to verilogA.
I wanna describes an analog block which has a function of differentiating.
So, I describes a sentence as below:
"V(out)<+ ddt(V(in))"
But however, when using spectre to simulate it.
There is error like "V(t0,out)= 6.28 GV exceeds the blowup limit".
There is a case. When the input wave voltage changes very sharp, the differential result will be infinitely large.
So how to describe a bound for the differentiated value? How to set the limit?
Thanks in advance.
Sumit Adhikari
Re: question on the "ddt" usage
Reply #1 - Apr 3rd, 2011, 12:38pm
There are two questions :
1. How is the input signal in nature  ?
2. What is that the output is driving ?
Sumit
boe
Reply #2 - Apr 4th, 2011, 1:50am
Patrick520,
What do you want to do? Increase the blowup limit (for which simulator?) or change the value of the derivative?
B O E
Reply #3 - Apr 4th, 2011, 12:04pm
Patrick520 wrote on Apr 3rd, 2011, 8:12am:
Hi!
Verilog-A provides the "slew" filter to do this, I believe.
