Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 19
th
, 2024, 6:19am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› bsource - convert to ADS
Previous topic
Next topic
bsource - convert to ADS (Read 6583 times)
apprentice
Apr 04
th
, 2011, 5:06pm
vb ( 3 2 ) bsource v = i(va)*5 + 1
va ( 2 1 ) vsource dc = 0
To convert the above netlist to a schematic in Agilent ADS, what's the right way? (Eqn based-nolinear component? Nonlinear CCVS?)
thanks
IP Logged
apprentice
Re: bsource - convert to ADS
Reply #1 -
Apr 4
th
, 2011, 7:33pm
thanks for hint.
not sure if SDD1P or SDD2P should be used.
tried SDD2P.
could you comment the attached screen capture?
IP Logged
Reply #2 -
Apr 6
th
, 2011, 9:31am
If I were doing it, I'd use a simple CCVS with a gain of 5 in series with a 1-V dc voltage source.
(I don't know what SDD1P is.)
IP Logged
Reply #3 -
Apr 6
th
, 2011, 4:45pm
SDD1P = symbolically defined device - one port (I believe)
This seems all very complicated if all you want is a 5 Ohm resistor in series with a 1V voltage source.
IP Logged
apprentice
Reply #4 -
Apr 6
th
, 2011, 6:10pm
thanks Geoffrey and Ken.
I'll think more about the model and try the schematics as you suggested.
IP Logged
Reply #5 -
Apr 7
th
, 2011, 7:16am
Ken's absolutely right (unless node "2" has other connections ...).
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
