Dec 13th, 2025, 10:05am
Assignment after coordinate transformation (Read 1941 times)
Richardsim
Apr 11th, 2011, 12:23am
Part of a model I've implemented is shown below:
module Modulename (ttranstip, tphitip);
   inout [0:1] ttranstip;
   inout tphitip;
   kinematic [0:1] ttranstip;
   kinematic gnd;
   rotational tphitip, rotgnd;
   ground gnd, rotgnd;
parameter real alpha = 0;
parameter real k1=2;
parameter real k2=1;
parameter real k3=1;
parameter real k4=2;
parameter real k5=1;
// temp values
   real  gl11, gl12, gl21, gl22, Fxtip, Fytip, Mtip, xtip, ytip, phitip, T, Iz, ke,
   kb, A, kFxd_xwumind, kFxd_xwdminu, Lb, Tautemp, xglobal, yglobal;
//alpha,k1, k2, k3, k4
analog begin
gl11 = cos(alpha);
gl12 = -sin(alpha);
gl21 = sin(alpha);
gl22 = cos(alpha);
xtip = k1*Fxtip + k2*Fytip;
ytip = k3*Fxtip + k4*Fytip;
Tautemp = Tau(tphitip,rotgnd);
Theta(tphitip) <+ k5*Tautemp;
Pos(ttranstip[0]) <+ gl11*xtip + gl12*ytip;
Pos(ttranstip[1]) <+ gl21*xtip + gl22*ytip;
F(ttranstip[0],gnd) <+ gl11*Fxtip + gl12*Fytip;
F(ttranstip[1],gnd) <+ gl21*Fxtip + gl22*Fytip;
This compiles succesfully. However, in simulation errors occur. Intuitively, only the Theta(tphitip) <+ assignment is a neat link between through and across variables at the terminals (no coordinate transformation for the angular coordinate). Apart from rewriting the set of equation to obtain a direct expression between through and across variables, can I adjust the code above to get it to work?
Re: Assignment after coordinate transformation
Reply #1 - Apr 11th, 2011, 6:30am
Did you intentionally leave out the assignments to Fxtip and Fytip?
Why do you have "gnd" only in
and not in
Pos(ttranstip[0])
