Jul 18th, 2024, 10:16pm
cadence ocean script switching model files (Read 4054 times)
Zorro
Apr 27th, 2011, 3:13am
Can please somebody help me to modify an ocean script? Ocean scripts are new to me.
the ocean file is running but I need to switch among different model files.
   I have this:
   modelFile(
   '("$PDK_DIR/at77000/analog_artist/models/spectre/model_corners/MOS_nom_RES_nom_
CAP_nom.scs" "")
   and it is working.
   now I want to, let's say run the same ocean script but using 3 different model files:
   "$PDK_DIR/at77000/analog_artist/models/spectre/model_corners/MOS_nom_RES_nom_CA
P_nom.scs"
   "$PDK_DIR/at77000/analog_artist/models/spectre/model_corners/MOS_bcs_RES_high_C
AP_high.scs"
   "$PDK_DIR/at77000/analog_artist/models/spectre/model_corners/MOS_bcs_RES_nom_CA
P_low.scs"
   what is the best way to do this? I have tried different ideas but without success.
   my idea is to do something like this:
   model_path="$PDK_DIR/at77000/analog_artist/models/spectre/model_corners/"
   corner1=strcat(model_path "/MOS_nom_RES_nom_CAP_nom.scs")
   corner2=strcat(model_path "/MOS_bcs_RES_high_CAP_high.scs")
   corner3=strcat(model_path "/MOS_bcs_RES_nom_CAP_low.scs")
   and then to use a foreach. but I don't get it to work because of syntax errors or maybe because it is not the correct way to do it.
   can please somebody have a look at this and if possible provide me an (written) example?
   thank you!
Zorro
Re: cadence ocean script switching model files
Reply #1 - Apr 28th, 2011, 2:58am
Hi All,
for those who are interested I found a method to switch between the models.
maybe the code is not the most elegant but it fulfills the desired objective.
as a point of reference here is the code:
;;;;;;;;;;;;;;;;;;;;;;;;; Part1
comment the following lines:
;modelFile(
;   '("$PDK_DIR/at77000/analog_artist/models/spectre/model_corners/MOS_bcs_RES_high_
CAP_low.scs" "")
use instead:
model_path="/design/libs/at77000/v0.7/at77000/analog_artist/models/spectre/model
_corners"
list1      =      strcat(model_path  "/MOS_bcs_RES_high_CAP_high.scs      ")
list2      =      strcat(model_path  "/MOS_bcs_RES_high_CAP_low.scs      ")
list3      =      strcat(model_path  "/MOS_bcs_RES_low_CAP_high.scs      ")
list4      =      strcat(model_path  "/MOS_bcs_RES_low_CAP_low.scs      ")
etc etc etc, define here all the different models
;;;;;;;;;;;;;;;;;;;;;;;;; Part2
then define a list where you can select which models will be used in the loop, for example
corner_list = list(list1 list2 list4 )
;;;;;;;;;;;;;;;;;;;;;;;;; Part3
then use a loop:
foreach( corner corner_list
           modelFile( corner)
           run()
and that's it.
Best Regards and hope it is helpful for someone!
Reply #2 - Apr 28th, 2011, 5:32am
Thanks for posting the solution!
Zorro
Reply #3 - Apr 28th, 2011, 6:43am
you are welcome!
it could be helpful for someone starting ocean scripts.
regards!
