sutapanaki
Thank you, guys, for the response. I'm using wavescan, which is now called viva. Long time ago, when Pspice was still MicroSim I used to use it and many things were easy to be done with it. There is no x-axis variable in cadence's calculator now. There is xval, which gives you a single x-axis value for some conditions. From ac analysis, spectre saves frequency, real and imaginary parts. What I want is access to the frequency vector, that's all. It should be simple. I talked to cadence support and they said write a skill. But if for plotting a line I have to write a skill, I may as well get the data in matlab and work there. It approximately the same effort.
