Jul 17th, 2024, 2:36pm
verilogA digital code shifter (Read 15492 times)
newic
May 07th, 2011, 8:38am
try to model a digital code shifter in verilogA. It got syntax error.
"result[0:<<--? 7] = {1 0 0 1 1 1 0 1};"
Looks like I could not define the content of the array.
       integer result[0:7] ;
       analog begin
               @( initial_step) begin
                       result[0:7] = {1, 0, 0, 1, 1, 1, 0, 1};
               @( cross( V(clk)-vth, 1)) begin
                       temp = result[i];
                       i = i + 1;
                       if( i >=8)
                               i=0;
rfidea
Europe
Re: verilogA digital code shifter
Reply #1 - May 8th, 2011, 11:10pm
I'm not sure that you can set the value of all elements in results[0:7] as you try to do. Sometimes verilogA is limited in this kind of operations. You can try something like results[0] = 1; results[1] = 0; ...
It is not beatiful but I think it will work...
newic
Reply #2 - May 8th, 2011, 11:31pm
I am aware of doing that. Is there a better way?
Because i need to create a long patterns for different cases.
That shift register is to do a simple test case only
boe
Reply #3 - May 9th, 2011, 10:29am
Newic,
According to Cadence V-A Language reference (Sept 2010) you can use `{} to initialize parameter/localparam arrays. However, I don't know if that works elsewhere.
B O E
PS: Did you try result = ....?
newic
Reply #4 - May 20th, 2011, 5:56pm
seems like i got to assign the bit one by one.
Reply #5 - May 23rd, 2011, 10:43am
Following boe's tip, perhaps you could:
 `define MYMAX 7
 localparam integer startval[`MYMAX:0] = `{1, 0, 0, 1, 1, 1, 0, 1};
 integer result[`MYMAX:0] ;
 integer k;
 @(initial_step) begin
   for (k=0; k<=`MYMAX; k=k+1) result[k] = startval[k];
