Jul 18th, 2024, 12:40am
Pages: 1 2
stability & phase margin simulation (Read 26270 times)
buddypoor
Bremen, Germany
Re: stability & phase margin simulation
Reply #15 - Jun 07th, 2011, 8:29am
Sorry, it was F. Wiedmann who has collected something about phase margin:
http://sites.google.com/site/frankwiedmann/loopgain
newic
Reply #16 - Jun 8th, 2011, 6:42am
Hi all, thx for the sharing.
Regarding to my previous post to plot PSR simulation for that regulator.
I inject ac noise at the power supply and measure VF(vout) to obtain the PSR result. My question is do I need to break the feedback loop for this case? In my opinion, breaking the feedback path is not needed. Am I right?
buddypoor
Bremen, Germany
Reply #17 - Jun 8th, 2011, 7:14am
Yes, that's correct. You must not open the loop for this case, since the PSRR is defined for the nominal operating conditions, of course.
Opposite to this case, the phase margin is defined for the loop gain, which needs signal injection into the (open) loop.
newic
Reply #18 - Jun 8th, 2011, 7:18am
Billions thx to buddypoor.
to complete the discussion, the comparison with 3 cases are shown here.
case1  ( incorrect LC method)
case2  (stb)  -
case3  (correct LC method)
newic
Reply #19 - Jun 8th, 2011, 7:22am
reupload
buddypoor
Bremen, Germany
Reply #20 - Jun 8th, 2011, 9:20am
What is the difference between cases 1 and 3?
newic
Reply #21 - Jun 8th, 2011, 6:19pm
case1 --> inject ac at the plus input of opamp
case3  -> inject ac  in series with big cap at the minus input of opamp & ac ground the plus input (which is suggested by buddypoor)
case2 -> same as in the 2nd figure, the ac is injected at the plus input of opamp    (using stb) ...
could someone comment on the case2 method. I am new to stb method.
from the comparison, they are almost alike at certain range. But the phase difference is relative difference in term of the starting phase
buddypoor
Bremen, Germany
Reply #22 - Jun 8th, 2011, 11:48pm
Hi newic,
just for my and your understanding:
When you start the simulation at very low frequencies (1mHz for example), you will notice that there is a difference at low frequencies between cases 1 and 3. Case 1 gives you not the loop gain (which must be negative) but the positive gain of the closed loop circuit.
However, because the inv. input has a large C to ground, both are identical in magnitude for medium and higher frequencies.
Nevertheless, case 1 does not comply with the phase margin definition, which applies only to the loop gain.
newic
Reply #23 - Jun 11th, 2011, 8:51am
just now i resimulate the case3. This round i got phase start at 180o instead of -180o...   Cheesy
buddypoor
Bremen, Germany
Reply #24 - Jun 12th, 2011, 5:55am
newic wrote on Jun 11th, 2011, 8:51am:
Is this a problem for you? I don`t think so if the phase becomes more negative for rising frequencies.
newic
Reply #25 - Jun 12th, 2011, 6:37am
sorry, i am bit slow.
In the case3, i got the phase starts at -180o and go toward -360o for higher frequency as shown in the overlapping figure.
This round, (not sure what i did), I got the phase starts at +180o and go toward 0o for higher frequency.
It puzzles me, how could I read the Phase Margin in these two cases? I think one of the results must be wrong right.
buddypoor
Bremen, Germany
Reply #26 - Jun 12th, 2011, 8:20am
Do you see any difference beteween plus and minus 180 deg?
Or between zero and -360 deg? Me not!
I think it (a) depends on your simulator if it prefers -180 deg or +180 deg, or (b) it depends on the lowest frequency you are simulating.
In any case, the phase margin is the difference (at the magnitude cross-over frequency) between the actual phase and zero deg (equivalent to -360 deg).
newic
Reply #27 - Jun 12th, 2011, 7:21pm
Hi buddypoor,
Got it!
Thank you very much!!  :)
Pages: 1 2
