Jul 18th, 2024, 4:30am
Capacitive DC-DC: Simulation problem (Read 5682 times)
melbadry
Jun 14th, 2011, 7:22am
I am trying to simulate the efficiency of an ideal step-up capacitive DC-DC converter (Step-up charge pump). The problem is I get the output power is greater than the input power (The output current = Input current and output voltage > input voltage)
I use ideal switches and caps in my test-bench, and my load is a simple current source (I switch it in after the circuit starts-up and settle to its no-load value)
What is this problem caused by? What the right way to simulate efficiency?
Re: Capacitive DC-DC: Simulation problem
Reply #1 - Jun 14th, 2011, 1:49pm
Shouldn't the input current be greater than the output?  Otherwise it seems like your circuit is creating power.
It also seems, if you only have caps and ideal switches, then you have nothing that will dissipate power.
melbadry
Reply #2 - Jun 14th, 2011, 1:54pm
Yes, exactly. That's why I am confused. The output power is higher than the input power!
boe
Reply #3 - Jun 15th, 2011, 1:25am
melbadry,
you give very little information, so we have to guess: Did you perhaps use the wrong sign for your load current?
B O E
JulianT
Swindon, UK
Reply #4 - Jun 15th, 2011, 3:58am
I have found the same problems in simulating capacitive DC-DC charge pumps - that is the input power is less than the output power. But changing the simulator from Spectre to BDAsim gave me a different answer - with the Pin > Pout.
Make sure that the pulse generation does not contribute to the output power - the phase1/phase2 'vpulse' should have high-impeance loads!
If you use ideal switches and change the on-resistance of the switch you'll find that the simulator will give other answers - sometimes wrong, somtimes appearing correct. Ideally you should get near 100% efficiency with ideal components.
I looked at the averaging of the input current and output voltage - no errors from the waveform post-processing. So I can anly assume that its due to the simulator solver not getting the solution accurate - trying different tolerance settings and/or timestep controls may help.
Good luck... Smiley
melbadry
Reply #5 - Jun 15th, 2011, 2:16pm
