Jul 16th, 2024, 9:35pm
can cadence plot signals automatically after PSS like transient? (Read 3385 times)
The Falcon
Jun 19th, 2011, 1:13am
Hi
In Cadence IC 6
could cadence plot pre-selected signals ( waveforms )  automatically after running pss analysis without going to direct plot / mainform ?
ADE do this in transient could it do that for pss also?
Re: can cadence plot signals automatically after PSS like transient?
Reply #1 - Jun 21st, 2011, 5:55pm
Choose the signal you want to plot in Results Browser after first run. In pss-td.pss, choose the signal, RMB click and select Calculator. Then the signal is put in the Calculator, looks like v("signal_name" ?result "pss-fd.pss").
After that, choose Outputs --> Setup in ADE. Get the expression from the Calculator and name it. Click OK or Apply to add the expression.
Now the PSS result for that signal will be plotted after next run.
Yawei
The Falcon
Reply #2 - Jun 28th, 2011, 5:12am
Thank you ywguo
