afridi
How can I get a reset input and reset the D-flip flop in the following code ? Your kind help would be appreciated as I have no knowledge of Verilog
module d_ff(vin_d, vclk, vout_q, vout_qbar); input vclk, vin_d; output vout_q, vout_qbar; electrical vout_q, vout_qbar, vclk, vin_d; parameter real vlogic_high = 5; parameter real vlogic_low = 0; parameter real vtrans_clk = 2.5; parameter real vtrans = 2.5; parameter real tdel = 3u from [0:inf); parameter real trise = 1u from (0:inf); parameter real tfall = 1u from (0:inf);
integer x; analog begin @ (cross( V(vclk) - vtrans_clk, +1 )) x = (V(vin_d) > vtrans); V(vout_q) <+ transition( vlogic_high*x + vlogic_low*!x, tdel, trise, tfall ); V(vout_qbar) <+ transition( vlogic_high*!x + vlogic_low*x, tdel, trise, tfall );
