Aug 15th, 2024, 7:49pm
how can cadence IC 6 simulate different parametric sweep in parallel (Read 5143 times)
The Falcon
Jun 28th, 2011, 5:09am
Hi
how can cadence IC 6 ADE LX simulate different parametric sweep in parallel?
by glopal parameters?
Re: how can cadence IC 6 simulate different parametric sweep in parallel
Reply #1 - Jun 28th, 2011, 9:39pm
Select Global Variables in Data View tab after opening adexl. Type in the numbers for the swept parameter, separated by space.  For example,
par_vdd  2.25 2.5 2.75
Then click the green run button.
The Falcon
Reply #2 - Jun 29th, 2011, 4:05am
Thanks ywguo, i know this method but how to make them runing in parallel on different processor?
rfidea
Europe
Reply #3 - Jun 29th, 2011, 1:20pm
You need to use a queue system, for example LSF or SGE. Then you use the "distributed" option under the "Job options" menu.
Reply #4 - Jun 29th, 2011, 5:47pm
Hi Falcon,
If you want to distribute those jobs on multi processors in one computer with IC 6 ADE-XL, it is not so complex for you to use a queue system like LSF or SGE.
Click adexl tab, choose Options --> Job Setup .... A form named Job Policy Setup pops up. The default value for Distribution Method is Local, which means all jobs run on multi-processors in one computer in the same time. The default value for Max. Jobs is 1, please increase the number so that all your jobs start to run immediately. Be careful to ask your administrator how many processors that computer has.
Yawei
