Hi Falcon,
If you want to distribute those jobs on multi processors in one computer with IC 6 ADE-XL, it is not so complex for you to use a queue system like LSF or SGE.
Click adexl tab, choose Options --> Job Setup .... A form named Job Policy Setup pops up. The default value for Distribution Method is Local, which means all jobs run on multi-processors in one computer in the same time. The default value for Max. Jobs is 1, please increase the number so that all your jobs start to run immediately. Be careful to ask your administrator how many processors that computer has.
Best Regards, Yawei
