Sep 18th, 2024, 12:53am
Step loading current in linear regulator (Read 2212 times)
newic
Jun 30th, 2011, 4:04am
After designing a linear regulator, i did a step response on the current loading from 0mA to max mA & from max mA to 0mA with a paramter tr (ramping rate).   I put a tr=10ns, i see a big voltage jump, which exceed the max electrical over stress condition of  transitors. What is the realistic ramping rate?
YaBiBi
CN
Re: Step loading current in linear regulator
Reply #1 - Jul 1st, 2011, 2:41am
100ns is much resonable for load transient. Indeed the undershoot or overshoot depends on your loop performance.
supermoment
Reply #2 - Jul 7th, 2011, 6:07pm
if the ramping rate frequency is higher than the bandwidth of the opamp, the opamp wont respond instantly, it needs some time.
