Aug 15th, 2024, 6:18pm
Negative cbb for BSIM4 (Read 1829 times)
taik
Jul 01st, 2011, 7:05am
We are currently having problem with transient convergence on a particular circuit.
Checking with the developer reveals that certain transistors in the circuit had negative cbb which causes this convergence issue.
They are now trying to get us to confirm that this cbb parameter cannot be a negative value.
Anyone has any idea on this?
Thank you in advance.
Re: Negative cbb for BSIM4
Reply #1 - Jul 8th, 2011, 5:58am
The BSIM models are known to have problems with transcapacitances like the intrinsic (channel) Cbs.  I don't recall ever seeing an example where Cbb was negative; usually, I would expect the junction capacitances to dominate over the channel capacitances.
