Hello everyone.
I try to be specific: I'm using the Cadence tools.
- I wrote some Verilog modules for a design (counter, shift registers, etc..)
- Using RTL Compiler I synthesis the design
- I load the desing in Encounter and I do P&R
- Send back the layout to Virtuoso
- Encounter produces a post-P&R verilog netlist
- Import the post-P&R verilog netlist in Virtuoso: this generates the schematic view for all the verilog blocks I wrote for this design
- Run DRC and LVS: during the LVS there is a mistake. One gate (NAND2) is supposed to have input A connected to VDD but Encounter did not make the connection. Ok, I do the connection and LVS is clean.
- Now I want to run AMS-simulations. I setup everything, netlist is ok and compiler is ok, but when I arrive at the Elaboration I receive the following error:
ncelab: *E,CUVNAS (<my_path>/counter_12bit/schematic/verilog.vams,206|19): segmentation of a signal
.VDD( VDD ), .A( VDD ), .B( reset ) );
Now, this is exactly the port that I connected by hand in Virtuoso and wasn't connected by Encounter (so, I guess there is something related here).
This connection has not been made by me, but it is the result of the synthesized netlist, so I guess that the synthesizer knew what it was doing when it connected the pin A of the NAND2 gate to VDD.
I assume this is some kind of "bug" or something that requires a workaround. I found 2 threads in this forum pointing to the same problem: the first was solved with an update of the tool (I'm already using the last version).
The second thread can be found here
http://www.designers-guide.org/Forum/YaBB.pl?num=1249430631 but I have to admit it wasn't really helpful.
Do you have any ideas how to solve this problem?
thanks for the help
Konx
