Aug 3rd, 2024, 5:21pm
constant RLGC model in mtline (Read 2947 times)
newic
Aug 09th, 2011, 3:00am
Hi
How could I include a constant RLGC value into a mtline in cadence?
I use the format below as in the spectre reference. How could I remove the frequency information?
mtline model will include this file.dat
;comment
FORMAT FREQ :  L1:1 C1:1 R1:1 G1:1
0.001e9 :  0.27544e-6 0.50331e-9 0.12504e+5 0.31624e-2
;end of the file
Re: constant RLGC model in mtline
Reply #1 - Aug 16th, 2011, 5:55am
If you put the same RLGC values for 1 and 1e9 Hz, won't that give you a constant over all frequencies?
