Aug 17th, 2024, 3:19pm
How to force an unknown state to 0V or 1.8V? (Read 2479 times)
Kamal
Sep 23rd, 2011, 1:37am
I am running mixed simulations with AMS-ADE and I have an unknown state on one output of a digital block (output of a flip-flop before the reset).
How to force this unknown state to 0V or 1.8V?
During the simulation I use the "ConnRules_18V_full_fast".
boe
Re: How to force an unknown state to 0V or 1.8V?
Reply #1 - Sep 23rd, 2011, 1:57am
Kamal,
There are several options, you could e.g. change your connect module or use the force/release commands to override the signals at the beginning.
B O E
Kamal
Reply #2 - Sep 23rd, 2011, 3:00am
Thanks for your answer BOE, however could you be more explicit.
In fact, I am a beginner with mixed-simulations & AMS.
In the "Cadence AMS Simulator User Guide" there are force Command Examples but I do not understand how to use those commands in ADE.
boe
Reply #3 - Sep 23rd, 2011, 4:33am
Kamal,
If you use interactive simulation mode (Netlister & Run Options) the simulator starts with GUI, so you can enter commands in the console.
B O E
Kamal
Reply #4 - Oct 6th, 2011, 7:20am
Hi Boe,
I have following message when I try to use "force" command:
ncsim> force {test_Pll.I0.I0.I2.I31.vcofc_out} 4'b1010
ncsim: *E,SETAIA: Analog engine is active. Cannot force digital object: test_Pll.I0.I0.I2.I31.vcofc_out.
Any idea of the meaning of this message?
K.
boe
Reply #5 - Oct 6th, 2011, 7:37am
Hi Kamal,
try Code:
run -sync
before the force command. This should advance to the next time point where digital commands are permitted.
B O E
Kamal
Reply #6 - Oct 6th, 2011, 8:32am
Thanks Boe for your help, you command "run -sync" works.
I have a last question, do you know how to release the digital outputs after few nano seconds (10ns)?
K.
boe
Reply #7 - Oct 6th, 2011, 8:39am
Hi Kamal,
run 10ns
run -sync
release ...
B O E
Kamal
Reply #8 - Oct 7th, 2011, 6:00am
Thanks BOE.
Reply #9 - Oct 29th, 2011, 6:06pm
why not use an initial conditions definition?
undefined state is not always a bad thing, your test routine probably hits the "reset" early in the test bench anyhow.
boe
Reply #10 - Nov 1st, 2011, 4:22am
Jerry,loose-electron wrote on Oct 29th, 2011, 6:06pm:
Because the standard CMs are essentially a voltage source converting 'X' to VDD/2. This can be awkward even if it does not need to be "a bad thing", as you correctly pointed out.
- B O E
