Jul 17th, 2024, 5:38pm
tolerances in the cross function (Read 2617 times)
jmith
Sep 26th, 2011, 10:02am
How should handle the simulator the situation when the current and previous values vioalates the tolerance parameters: show an error message or ignore the event generation?
Re: tolerances in the cross function
Reply #1 - Sep 28th, 2011, 1:44pm
If I'm understanding your question correctly, the simulator should reject the timestep and choose a smaller one, such that the tolerances are met.
Spice simulators frequently reject timepoints -- they're trying to take the largest step they can, so as to finish the analysis faster, and often take too big a step such that they fail to converge or don't follow the shape of the waveform accurately.
jmith
Reply #2 - Sep 28th, 2011, 3:34pm
This is the same for ddt(expr, abstol)?
Reply #3 - Oct 7th, 2011, 7:37am
Yes, if the abstol isn't met, the timepoint should be rejected and a smaller step taken.
