Hello Guys,
I am doing post-PR simulation with AMS designer. Select
Cellview-based netlister with ncvlog, ncelab, ncsim. It stops in elaberation phase with the following error.
Code:ncelab: 09.20-s019: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
Elaborating the design hierarchy:
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
ncelab: *E,CUCFUN: instance 'FE_PHC668_rstn' of the unit 'DL07D1' is unresolved in 'csmc05mm01.xihu_dig:module'.
ncelab: *E,CUCFUN: instance 'FE_OFCC666_FE_OFN640_modout' of the unit 'NI01D5' is unresolved in 'csmc05mm01.xihu_dig:module'.
DL07D1 and NI01D5 are standard cells. I set the verilog file for standard file in
ADE -->
Simulation -->
Options -->
Compiler... -->
Library Files/Directories. All the standard cells are compiled into myDesign_sim library. Then I fill myDesign_sim library name in
Library list of
Global Bindings.
I have not figured out the cause. Any comments are appreciated.
Best Regards
Yawei
