Aug 14th, 2024, 10:22am
Balu-LNA design (Read 530 times)
prakash@191
India
Balu-LNA design
Oct 18th, 2011, 1:54am
I have designed balun-LNA using parallel combination of CS and CG stage.  My circuit has differential output and single ended input. I matched the input for 50ohms since it is single ended. But my doubt is how to match the differential output for 100ohms.
For output impedance matching, i have separately matched the output for 50ohms assuming virtual ground.(for both outputs of CS and CG buffer stages). After matching i lifted the virtual ground and the output capacitors will come in series. I replaced them with single capacitor ( series combination). I haved used capacitors for matching purpose at the output of buffer stages.
With this setup, i measured S22 by keeping port in between the terminals.
I want to know whether my way of thinking is correct?
Any help would be appreciated
« Last Edit: Oct 18th, 2011, 5:20am by prakash@191 »
