Aug 16th, 2024, 10:46pm
vpulse doesn't work in the AMS simulation (Read 5499 times)
dan_vol
US
Nov 02nd, 2011, 6:57pm
HI guys
I used a vpulse for the input of the VCO model (listing 22) in the Designer's guide to verilogAMS. I modified the $bound_step to 0.05n to accommodate the period of vpulse(0.5n). But the result turned out that the vpulse didn't work at all.  VCO's output is the same as when it's fed with a vdc. And vpulse is zero all the time.
And in the config view: vpules-spectre, res-spectre, VCO-verilogams, testbench-schematic.
Stop list: symbol
Best regards
Daniel
VCO code:
`include "disciplines.vams"
`include "constants.vams"
module vco_analog (out, in);
   parameter real Vmin=0;                  // minimum input voltage (V)
   parameter real Vmax=Vmin+1 from (Vmin:inf);      // maximum input voltage (V)
   parameter real Fmin=10000k from (0:inf);            // minimum output frequency (Hz)
   parameter real Fmax=2*Fmin from (Fmin:inf);      // maximum output frequency (Hz)
   parameter real ampl=1;                  // output amplitude (V)
   input in; output out;
   voltage out, in;
   real freq, phase;
   analog begin
     // compute the freq from the input voltage
     freq = (V(in) - Vmin)*(Fmax - Fmin) / (Vmax - Vmin) + Fmin;
     // bound the frequency (this is optional)
     if (freq > Fmax) freq = Fmax;
     if (freq < Fmin) freq = Fmin;
     // phase is the integral of the freq modulo 2p
     phase = 2*`M_PI*idtmod(freq, 0.0, 1.0, -0.5);
     // generate the output
     V(out) <+ sin(phase);
     // bound the time step
     $bound_step(0.05n);
Re: vpulse doesn't work in the AMS simulation
Reply #1 - Nov 2nd, 2011, 8:02pm
If vpulse is not working, why are you showing us the VCO?
dan_vol
US
Reply #2 - Nov 2nd, 2011, 11:49pm
Ken Kundert wrote on Nov 2nd, 2011, 8:02pm:
Thanks for reply.
The vpulse is from analogLib. voltage1=0, voltage2=1. I want to show you everything about this problem, because I am not sure where it arise from.
-Daniel
Reply #3 - Nov 3rd, 2011, 9:26am
Is there more to this simulation? Is it just a voltage source driving the VCO model, or are there other components?
Is it possible that the timepoints chosen by the simulator are so loose that it is not sampling the output of the voltage source when the output is high?
boe
Reply #4 - Nov 3rd, 2011, 10:38am
Ken,
bound_step should prevent the timestep issue.
Perhaps somewhere the "n" (for nanoseconds) is missing...?
- B O E
dan_vol
US
Reply #5 - Nov 3rd, 2011, 7:51pm
Ken Kundert wrote on Nov 3rd, 2011, 9:26am:
There are just 3 components. They are uploaded in the attachment. And I tested other sources like vpwl and vdc(test_source folder in the attachment), I found that only if the stoplist in the Hierarchy Editor contains spectre, the results  will be right.
But  when the stoplist of test_vco_analog example is changed to include spectre, irun would report error like the following:
ncelab: *E,CUVDNF (./netlist.vams,23|20): Could not determine discipline for this expression .
    ) I0 ( .out(net3), .in(net1));
ncelab: *E,CUVDNF (./netlist.vams,23|31): Could not determine discipline for this expression .
   net1, cds_globals.\gnd! );
ncelab: *E,CUVDNF (./netlist.vams,26|7): Could not determine discipline for this expression .
resistor #(.r(1K)) R0 (net3, cds_globals.\gnd! );
I consulted to the user guide(cdshiereditor.pdf). But I don't know what it exactly means by leaf node. And what's the difference among symbol , symbol spectre and verilogams spectre in the stoplist?
-Daniel
dan_vol
US
Reply #6 - Nov 3rd, 2011, 7:55pm
boe wrote on Nov 3rd, 2011, 10:38am:
Ken,
- B O E
I checked again..Actually vdc and vpwl don't work either. I am going to write the source in verilogams now. But I wonder why the problem happened.
-Daniel
Reply #7 - Nov 3rd, 2011, 8:47pm
You are not going to get many people to go through the trouble of trying to open your cadence database, and even if they did you did not give enough to reproduce the problem. You'd be better served communicating with words and pictures. I will look at a netlist if you collapse it into one file, though I don't know if anyone else will.
