Aug 17th, 2024, 5:20am
Error: Shared Waveform Token id(s) are null??? (Read 2026 times)
BenMartin
Nov 29th, 2011, 4:37pm
Help.
In ADE, an error started showing up in the calculator.  It keeps saying:  <Calculator>  Evaluation error(Cannot read waveform.  Shared Waveform token id(s) are null).  Expression: VT("I0/I11/net90")
As a result, I can't really use the calculator.
Obviously the last bit changes, depending on what I am trying to plot.  I never used to get this error, and I can't figure out what is wrong.  I tried erasing the simulation folder and the .artist_states, to see if something got corrupted.  It seems like many of the schematics are generating this errors (more than just one).
Any help is appreciated.
Ben
BenMartin
Re: Error: Shared Waveform Token id(s) are null???
Reply #1 - Nov 30th, 2011, 12:51am
...the same design files were tried on another machine in our lab, and magically the calculator works. - The issue is related to the software setup, not some setting in ADE.  This becomes an IT issue.
Thanks anyways all.
