Aug 16th, 2024, 10:21am
Spectre don't recognize "0" as gnd? (Read 3193 times)
mjun0mjun
Dec 06th, 2011, 6:40am
Hi guys,
   I met a problem in my post_simulation which cost me much time. I used Calibre to extract parasitic parameters. And in the generated Calibre view I find something strange, that is, all the parasitic capacitors to ground are connected to node '0', not my ground in the design--'agnd', and the node '0' is connected to the 'agnd' through a capacitor. Part of the printscreen of the Calibre view is shown in the figure 0_gnd.JPG below. What's more, I simulate the voltage of the node '0', which is not constant zero, but changes with time. So all the simulation results are wrong. Could someone help me figure this out?
Thank you~~
Ma Jun
ahutianyi
Re: Spectre don't recognize "0" as gnd?
Reply #1 - Dec 23rd, 2011, 7:00am
I got the same problem which confused me so much.Waiting for someone to give the solution. Smiley
rfidea
Europe
Reply #2 - Dec 25th, 2011, 2:39am
Try the Calibre support at Mentor Graphics!
Reply #3 - Jan 11th, 2012, 7:26am
I agree with rfidea -- it's probably a configuration setup error on your part with Calibre.  Ie, maybe you're supposed to specify the name of your ground note in the setup, and it defaults to 0 because you failed to specify it.
