Aug 17th, 2024, 1:13am
VCVS for differential signalling (Read 857 times)
Larry_80
Dec 06th, 2011, 12:43pm
Hello All,
In spice deck, one can measure the difference btw 2 node voltage by using E element with gain=1 i.e VCVS. I want to know how to measure the difference btw 2 curents I(Vx1)-I(Vx2). Can i use a CCCS in hspice for this?
Re: VCVS for differential signalling
Reply #1 - Dec 6th, 2011, 4:03pm
depends on the particular EDA tool and its capabilities.
If the direct method of current montior and buffer is not there, people build (sort of) equivalent models using small series resistances (milliohm in model is not going to affect most circuit designs) which produce a voltage equivalent to current signal, then add-subtract-multiply voltages, and then convert back to a current.
Depends on the tool set, most better ones have ways of monitoring the currents directly.
raja.cedt
Reply #2 - Dec 7th, 2011, 2:23am
hello,
so you want to measure current difference, so fist convert current into voltage and then subtract.
raj.
Reply #3 - Dec 15th, 2011, 7:10am
Larry_80 wrote on Dec 6th, 2011, 12:43pm:
Hello All,
I don't recall whether you can have two input sensors in the hspice CCCS; I would probably use a pair of CCVS to generate voltages from the currents, then use a VCVS to compute the difference in the node voltages.
