Aug 16th, 2024, 11:30pm
Please interpret the waveform in Cadence.. (Read 544 times)
muffassir
Planet Earth
Dec 08th, 2011, 12:34am
Hi all ,
Here is the attached image ..
I want to know two things...
1)What i want to know is the interpretation in words of the Oval mark in the image.
Like this is the signal at the value of this...is there any variable..
2)On x-axis the signal which we sweeep in the dc analysis form appears and the output is on the Y axis.The signal which i am sweeping in the Parametric analysis is the signal whose waveform gets drawn...Is this always the case..Correct my above statement if its wrong...Or it all depends on the signals which i choose to be plotted in the output(ADE L)
View Profile WWW muffassir   IP Logged
Re: Please interpret the waveform in Cadence..
Reply #1 - Dec 17th, 2011, 6:09am
What do you expect?
Isn't that plot correct?
