Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 17
th
, 2024, 12:03am
Home
Help
Search
Login
Register
PM to admin
Design Languages
Verilog-AMS
› ADE can't find veriloga view
Previous topic
Next topic
ADE can't find veriloga view (Read 168 times)
Charlie
Dec 12
th
, 2011, 2:02pm
I have generated a veriloga view for my schematic in Cadence environment. The spectre netlister can't find the veriloga view. It can find my schematic view and the veriloga view is in the same cell.
I have changed my switch view list to have veriloga first. I even put veriloga in the stop view list (first).
I also tried making a config file and specifying which block to use veriloga for but the issue is the same.
I'm guessing that I have some sort of larger setup issue. Any ideas?
Thanks!
IP Logged
boe
Re: ADE can't find veriloga view
Reply #1 -
Dec 13
th
, 2011, 3:37am
Hi Charlie,
Verilog-A views are preprocessed after closing the editor. You should get a report on syntax checking etc. Only after this has completed successfully you can use the view.
Do you use a config view?
- B O E
IP Logged
Charlie
Reply #2 -
Dec 19
th
, 2011, 9:11am
Hi BOE,
Turns out Cadence required that I open and close the veriloga file again before it would recognize it. Weird that I'd have to do it twice. Since then I've had no problems.
Charlie
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
»» Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
