Jul 17th, 2024, 5:30am
how to set initial current in the inductor of the xtal model (Read 4530 times)
hiSkill_11
Jan 05th, 2012, 1:03am
Hi, I found it strange when I simulate the crystal oscillator with tran analysis in spectre. When I set the initial current of 1uA in the parameter of CDF of the inductor in the crystal model, I observed that the current of the inductor(sin wave) starts from 0 and begin to oscillate with 1mA amplitude, when I  set it of 1mA, it starts from 0 and begin to oscillate with 1A amplitude. Then the envelope begin to decay to a stable value about 900uA.  So, I am confused about relation ship between the initial current in the component parameter and the value at time 0, also the initial swing of the inductor current.  And how can I set the initial current in the inductor in order to make the crystal oscillator reach the stable state quickly? Thanks.
raja.cedt
Re: how to set initial current in the inductor of the xtal model
Reply #1 - Jan 5th, 2012, 9:50am
Go to convergence aid and set initial conditions. If you use hspice just use .ic command. What is there......
thanks,
raj.
rfcooltools.com
Reply #2 - Jan 5th, 2012, 9:54am
hi_Skill_11,
Here is what I do
Since you already where able to get to steady state once, plot the current wave form and record the value of 5 equally spaced points on a half period of the waveform starting at zero and ending at zero amps.  Then get a ipwl enter the 5 points and simulate it should be at steady state within a half period.
The Q of the xtal is large enough to cause many simulators with nominal settings to converge abnormally which is why you may have seen the 1A temporarily.
http://rfcooltools.com
Reply #3 - Jan 5th, 2012, 11:27am
This seemingly anomalous behavior is explained in section 4.3.5 of my "Designer's Guide to Spice and Spectre" book.
hiSkill_11
Reply #4 - Jan 6th, 2012, 1:28am
raja.cedt wrote on Jan 5th, 2012, 9:50am:
thanks,
raj.
In spectre, the convergence aid seems to have no way to set initial current but voltage. Thanks.
Reply #5 - Jan 6th, 2012, 1:33pm
Everybodey should have a copy of Ken's book on their shelf.
Also, the crystal Q is so high (10E5)that it is generally
a wise course of action to drop the Q down to
something a little friendlier, like Q=100 or so.
Recognize that this is a simulator thing and the actual crystal
is narrower. But if the center band attenuation is the same (usually 0dB)
things simulate a bit easier.
