Jul 17th, 2024, 4:38pm
Pages: 1 2
how to save the output digital data in a file using Verilog-A (Read 16004 times)
afridi
Jan 22nd, 2012, 5:28am
I have designed a CT delta-sigma modulator. I want to take the digital output into a text file so that I can process that data in MATLAB. I dont have a complete understanding of Verilog-A in the available cadence virtuoso suite of ver 5.1 . Could anyone share any model or code for this which I can add as a block.
I tried to use the following Spectre-AHDL code also from some reference
node [V, I] in, clk, out;
parameter real thres=1.65;
parameter integer dis_mod=1;
parameter string filename;
stream fptr;
integer count;
real inr;
real t=1e-9;
initial
fptr = $fopen(filename,"w");
count=0;
analog
inr = V(in);
if ($threshold( V(clk) - thres, 1 ))
$fstrobe(fptr,"%f \n", inr);
count=0;
V(out) <- $transition(inr,0,t,t);
but it shows me the following error
DC Analysis `dcOp'
Internal error found in spectre during DC analysis `dcOp'.  Please run
       `getSpectreFiles' or send the netlist, the spectre log file, the
       behavioral model files, and any other information that can help
       identify the problem to support@cadence.com.
   "/home/sohaib/SGB25VD/skel/cdb/DSM_blocks/file_dump/ahdl/ahdl.def" 16:
       Segmentation fault.
If someone could explain me this issue that would be helpful as well in solving my problem.
The more things you do, the more you can do.(Lucille Ball)
boe
Re: how to save the output digital data in a file using Verilog-A
Reply #1 - Jan 24th, 2012, 8:58am
Hi dfury,
afridi wrote on Jan 22nd, 2012, 5:28am:
DC Analysis `dcOp'
       Segmentation fault.
You have encountered a tool BUG. Contact Cadence support.
BTW, which tool versions do you use?
- B O E
afridi
Reply #2 - Jan 24th, 2012, 9:21am
How to find tool version? I am using Cadence Virtuoso 5.14
Reply #3 - Jan 24th, 2012, 11:52am
afridi wrote on Jan 24th, 2012, 9:21am:
Somewhere in the output before the error message, you should see the simulator name and version (Spectre 7.0.1_122, just to make up an example).
Forum Administrator
YaBB Administrator
Reply #4 - Jan 24th, 2012, 2:54pm
Or you can run "spectre -W".
afridi
Reply #5 - Jan 24th, 2012, 6:18pm
The version is Spectre 5.1.0
boe
Reply #6 - Jan 25th, 2012, 3:26am
Dfury,
afridi wrote on Jan 24th, 2012, 6:18pm:
that is an ancient version. I suggest you change to a recent one.
- B O E
afridi
Reply #7 - Jan 25th, 2012, 4:20am
ok. You mean to upgrade the whole Cadence suite or just Spectre?
Do you think the error is there because this version is old?
boe
Reply #8 - Jan 25th, 2012, 7:29am
Dfury,
Updating spectre should be enough. You should use a MMSIM 10.x or MMSIM 11.x.
Knowing Cadence design support, they will tell you to update first anyway; also, this problem is probably already solved.
- B O E
afridi
Reply #9 - Jan 25th, 2012, 7:31am
Kindly could you direct me to the solution of my initial problem?
boe
Reply #10 - Jan 25th, 2012, 7:36am
Dfury,
I usually use Verilog-A, not SpectreHDL; but the code seems not too bad to me. However, I would expect the line
inr = V(in);
directly before the line
- B O E
afridi
Reply #11 - Jan 26th, 2012, 5:54am
Hmmm, The error is still showing up. I guess there is some problem with its compiler.
Can anyone help me translate this into Verilog-A?
Reply #12 - Jan 27th, 2012, 6:54am
`include "disciplines.vams"
module myoutput( in, clk, out);
inout in, clk, out;
electrical in, clk, out;
parameter string filename = "default.txt";
integer fptr;
integer count;
real inr;
real t;
analog begin
  @(initial_step) begin
    t=1e-9;
    count=0;
  inr = V(in);
  @(cross( V(clk) - thres, 1)) begin
    count=0;
  V(out) <+ transition(inr,0,t,t);
  @(final_step) begin
    $fclose(fptr);
Reply #13 - Jan 27th, 2012, 6:56am
As I was translating, I had a few questions:
1) Why is count always 0?
2) Why is t a variable instead of a parameter?
afridi
Reply #14 - Jan 28th, 2012, 2:11am
hmm I dont know exactly,
This code I read from this thesis liu.diva-portal.org/smash/get/diva2:19990/FULLTEXT01
Pages: 1 2
