Jul 17th, 2024, 4:22pm
Pages: 1 2
how to save the output digital data in a file using Verilog-A (Read 16001 times)
boe
Re: how to save the output digital data in a file using Verilog-A
Reply #15 - Jan 30th, 2012, 5:27am
Geoffrey_Coram wrote on Jan 27th, 2012, 6:56am:
As I was translating, I had a few questions:
1) Why is count always 0?
2) Why is t a variable instead of a parameter?
As already mentioned, I would expect
  @(cross( V(clk) - thres, 1)) begin
    inr = V(in);
    $fstrobe(fptr,"%f \n", inr);
    count=0;
instead of
  inr = V(in);
    count=0;
Anyway, neither code should cause internal errors on current Spectre versions.
- B O E
Reply #16 - Feb 1st, 2012, 10:14am
boe -
Well, that's an interesting question: is the output supposed to change only on the clock ( inr = V(in) inside the cross event block, as you expect) or always.
Because there's a transition filter, I guess I would tend to agree with you; it's a bad idea to put a transition on a continuous signal, but we don't actually know anything about what's connected to "in"
But this thread is mostly about writing the digital data to a file, so I wasn't paying attention to that.
Forum Administrator
YaBB Administrator
Reply #17 - Feb 1st, 2012, 3:07pm
Never ever do the following:
inr = V(in);
V(out) <- $transition(inr,0,t,t);
In other words, the first argument to the transition function should never be a continuous function of an electrical signal, even if you believe the electrical signal is constant. In contrast, the following is perfectly fine:
    inr = V(in);
The difference her is that inr is set in an event block and so cannot vary continuously with V(in).
Many times I have seen code that looks like the following:
if (...)
    val = 1;
else
    val = 0;
V(out) <+ transition(val*V(vdd), 0, 10n);
Such code leads to heartbreak and misery. The problem is that V(vdd) is computed by the simulator, and can change slightly from time point to time point (often time these changes are at the attovolt level). Those changes will activate the transition function, which limits the time steps and slow the simulation. You should instead use:
if (...)
    val = 1;
else
    val = 0;
V(out) <+ V(vdd)*transition(val, 0, 10n);
afridi
Reply #18 - Feb 7th, 2012, 3:11am
Thank you everyone for your insight.
The verilog-A code gives error at
parameter string filename ="default.txt"
when I remove the word "string" it works. any idea what it is?
The more things you do, the more you can do.(Lucille Ball)
afridi
Reply #19 - Feb 7th, 2012, 4:26am
boe wrote on Jan 30th, 2012, 5:27am:
    inr = V(in);
    count=0;
instead of
  inr = V(in);
    count=0;
- B O E
What I understand is,that the inr in the first case would save the its values after the clock voltage crosses over the threshold, but in the second case it will save the value before the clock voltage?
Then is the second approach completely wrong? or their effect is the same?
boe
Reply #20 - Feb 7th, 2012, 10:04am
Afridi,
afridi wrote on Feb 7th, 2012, 4:26am:
No, in the first case inr changes at every simulator time step, while in the other case it changes only at clock edge. This will effectively cause the output V(out) to be sampled in the second case. See also Geoffrey's comment (reply #16).
The difference is in V(out) and how efficiently the output signal is simulated. See Ken's post for the explanation why. If you remove the contribution statement to V(out), both cases should create the same output file.
afridi wrote on Feb 7th, 2012, 3:11am:
Apparently (your version of)  the simulator does not support this syntax.
- B O E
Reply #21 - Feb 7th, 2012, 12:27pm
"string" was not part of Verilog-AMS in the beginning, but some simulators allowed you to specify a string literal (something in "quotes") -- digital Verilog allowed some conversion between characters and 8-bit "reg" data values.  Since "string" wasn't a keyword, you couldn't use it, but Verilog has some automatic parameter type determination, so you could specify a string literal as the default value and this would effectively make the parameter of type string.
boe
Reply #22 - Feb 8th, 2012, 3:39am
Geoffrey,
however, recent versions of the Cadence Verilog-A Language Reference contain this parameter string syntax. So current versions of Spectre should understand this.
- B O E
Reply #23 - Feb 9th, 2012, 8:39am
Ah, but in another thread, Afridi admitted to running 5.10 (and was admonished there to get a more recent version).
Pages: 1 2
